Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
With this guide you will learn how to replace faulty battery spring contacts that may have been disconnected from motherboard or corroded by and exploding battery.
  1. Remove the battery compartment cover.
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Locate and remove the screw next to the battery compartment lid.
    • Locate and remove the screw next to the battery compartment lid.
  3. Locate the interlocking pegs along the seam of the device's casings.
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. The battery contact springs may prevent the case from separating.
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. The casing protecting the USB and headphone jacks must be removed.
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. You now have access to all components found on the inside of the device!
    • You now have access to all components found on the inside of the device!
  7. Locate both battery spring contacts, if necessary, on the motherboard. Locate both battery spring contacts, if necessary, on the motherboard.
    • Locate both battery spring contacts, if necessary, on the motherboard.
  8. Apply heated soldering iron to points where the contacts are soldered to the motherboard. Apply heated soldering iron to points where the contacts are soldered to the motherboard.
    • Apply heated soldering iron to points where the contacts are soldered to the motherboard.
  9. Soldering irons, when heated, are very hot and can potentially burn the user.
    • Soldering irons, when heated, are very hot and can potentially burn the user.
    • Be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  10. With solder melted, remove battery spring contacts from the motherboard.
    • With solder melted, remove battery spring contacts from the motherboard.
  11. Replace spring contacts with new ones.
    • Replace spring contacts with new ones.
  12. There may be some solder in the way of the spring contacts' metal contacts. If this occurs simply melt the solder to create room for the contacts.
    • There may be some solder in the way of the spring contacts' metal contacts. If this occurs simply melt the solder to create room for the contacts.
  13. With the new battery spring contacts in place, use the soldering iron to apply new solder to the connection points. Be sure to allow the new solder to cool and harden.
    • With the new battery spring contacts in place, use the soldering iron to apply new solder to the connection points.
    • Be sure to allow the new solder to cool and harden.
Conclusione
James Thorne
Membro da: 05/11/2013
638 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Membro di UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 26
Tutti i Tempi: 500
