Parti
Nessuna parte richiesta.
  1. Slide the back cover forward toward the top of the device with your thumb.
    • Slide the back cover forward toward the top of the device with your thumb.
  2. The back cover is now separated from the device.
    • The back cover is now separated from the device.
  3. Apply a fingernail or a plastic opening tool to the base of the battery.
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. Lift up gently.  The battery should come up and out.
    • Lift up gently. The battery should come up and out.
  5. The battery is now removed from the device.
    • The battery is now removed from the device.
  6. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  7. Remove the two black .265" screws at the base of the device.
    • Remove the two black .265" screws at the base of the device.
  8. Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  9. Slide the rear case cover toward the top of the device with your thumb to release it.
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  10. The rear case cover can now be separated from the device.
    • The rear case cover can now be separated from the device.
  11. Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  12. Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  13. Open the case cover starting on the side most distance from the buttons.
    • Open the case cover starting on the side most distance from the buttons.
  14. Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  15. You can now safely remove the front case cover from the device.
    • You can now safely remove the front case cover from the device.
Conclusione
Nicolas Coffey
Membro da: 27/01/2012
43 Reputazione
4 Guide realizzate
Cal Poly, Team 3-30, Amido Winter 2012 Membro di Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,094
