Salta al contenuto principale
Samsung YP-P3 Case Backplate Replacement
Cosa ti serve
  1. Samsung YP-P3 Case Backplate Replacement, Case Backplate: passo 1, immagine 1 di 1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Case Backplate Replacement: passo 2, immagine 1 di 1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Case Backplate Replacement: passo 3, immagine 1 di 2 Samsung YP-P3 Case Backplate Replacement: passo 3, immagine 2 di 2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 721
