Salta al contenuto principale
Samsung WB850F Lens Assembly Replacement
Cosa ti serve
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, immagine 1 di 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, immagine 2 di 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: passo 2, immagine 1 di 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: passo 3, immagine 1 di 2 Samsung WB850F Lens Assembly  Replacement: passo 3, immagine 2 di 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, immagine 1 di 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, immagine 2 di 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, immagine 3 di 3
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: passo 5, immagine 1 di 2 Samsung WB850F Lens Assembly  Replacement: passo 5, immagine 2 di 2
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: passo 6, immagine 1 di 1
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro di USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Membri
8 Guide realizzate
2 Commenti
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Replica
I am forward to hearing from you....
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,396
