Salta al contenuto principale
Samsung WB850F Control Panel Replacement
Cosa ti serve
  1. Samsung WB850F Control Panel Replacement, Control Panel: passo 1, immagine 1 di 3 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, immagine 2 di 3 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: passo 2, immagine 1 di 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: passo 3, immagine 1 di 2 Samsung WB850F Control Panel Replacement: passo 3, immagine 2 di 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
Conclusione
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro di USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Membri
8 Guide realizzate
Un commento
Only problem .. Where can I buy a replacement control panel.
D Traynor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 704
