Salta al contenuto principale
Samsung WB350F Rear Case Replacement
Cosa ti serve
  1. Samsung WB350F Rear Case Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung WB350F Rear Case Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung WB350F Rear Case Replacement, Rear Case: passo 1, immagine 3 di 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: passo 2, immagine 1 di 3 Samsung WB350F Rear Case Replacement: passo 2, immagine 2 di 3 Samsung WB350F Rear Case Replacement: passo 2, immagine 3 di 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: passo 3, immagine 1 di 3 Samsung WB350F Rear Case Replacement: passo 3, immagine 2 di 3 Samsung WB350F Rear Case Replacement: passo 3, immagine 3 di 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: passo 4, immagine 1 di 1
    • Remove the plastic casing, exposing the inner workings of the camera.
Conclusione
Zachary Bourgault
Membro da: 03/04/16
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 695
