Salta al contenuto principale
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: passo 1, immagine 1 di 3 Samsung WB350F Battery Replacement, Battery: passo 1, immagine 2 di 3 Samsung WB350F Battery Replacement, Battery: passo 1, immagine 3 di 3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: passo 2, immagine 1 di 1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
Conclusione
Un commento
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,857
