Salta al contenuto principale
Samsung WB2100 Back Cover Assembly Replacement
Cosa ti serve
  1. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: passo 1, immagine 1 di 3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: passo 1, immagine 2 di 3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: passo 1, immagine 3 di 3
    • Remove the 7 screws on the outside of the camera
    • Two 5 mm PH000 screws on the right side of the camera body
    • Four 3mm PH000 screws on the bottom and the left side of the camera body.
    • Use the plastic spundger to push the back casing out. Start from the right side and work your way clockwise around the case.
    • The HDMI / AV tab might fall out. this is supposed to happen as it is not screwed into place in the back casing.
  2. Samsung WB2100 Back Cover Assembly Replacement: passo 2, immagine 1 di 2 Samsung WB2100 Back Cover Assembly Replacement: passo 2, immagine 2 di 2
    • Disconnect the set of wires from the back casing to the motherboard. Do this by using the plastic spundger to flip the black tab up and the wires will pull out.
    • Unscrew the four 3 mm and two silver 1 mm PH000 screw from the green logic board
Conclusione
Mason Ricks
Membro da: 01/20/16
282 Reputazione
2 Guide realizzate
USF Tampa, Team 15-3, Remmell Spring 2016 Membro di USF Tampa, Team 15-3, Remmell Spring 2016
USFT-REMMELL-S16S15G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 342
