Introduzione
This guide provides a walkthrough on replacing the Samsung WB150F motherboard if your device is failing to boot or constantly glitches.
The motherboard controls all functions of the camera.
Before using this guide, inspect the battery to ensure that the device is receiving power.
Prior to beginning, make sure to remove the battery from your camera and disconnect from any external power source.
Cosa ti serve
The location of the battery compartment can be found on the underside of the camera.
Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
Note: removing the back shell does not require removing anymore screws, it should just snap off.
Disconnect the ribbon from the flash assembly.
Disconnect two ribbons from the lens assembly as shown in the second picture.
Disconnect the ground wire from the motherboard as shown in the third picture.
