Salta al contenuto principale
Samsung WB150F Motherboard Replacement
Cosa ti serve
  1. Samsung WB150F Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • The location of the battery compartment can be found on the underside of the camera.
  2. Samsung WB150F Motherboard Replacement: passo 2, immagine 1 di 2 Samsung WB150F Motherboard Replacement: passo 2, immagine 2 di 2
    • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
  3. Samsung WB150F Motherboard Replacement, LCD Screen: passo 3, immagine 1 di 1
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  4. Samsung WB150F Motherboard Replacement: passo 4, immagine 1 di 3 Samsung WB150F Motherboard Replacement: passo 4, immagine 2 di 3 Samsung WB150F Motherboard Replacement: passo 4, immagine 3 di 3
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  5. Samsung WB150F Motherboard Replacement: passo 5, immagine 1 di 1
    • Your camera should now look like the camera in the photo.
  6. Samsung WB150F Motherboard Replacement: passo 6, immagine 1 di 2 Samsung WB150F Motherboard Replacement: passo 6, immagine 2 di 2
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  7. Samsung WB150F Motherboard Replacement: passo 7, immagine 1 di 3 Samsung WB150F Motherboard Replacement: passo 7, immagine 2 di 3 Samsung WB150F Motherboard Replacement: passo 7, immagine 3 di 3
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  8. Samsung WB150F Motherboard Replacement: passo 8, immagine 1 di 3 Samsung WB150F Motherboard Replacement: passo 8, immagine 2 di 3 Samsung WB150F Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
  9. Samsung WB150F Motherboard Replacement, Motherboard: passo 9, immagine 1 di 3 Samsung WB150F Motherboard Replacement, Motherboard: passo 9, immagine 2 di 3 Samsung WB150F Motherboard Replacement, Motherboard: passo 9, immagine 3 di 3
    • Disconnect the ribbon from the flash assembly.
    • Disconnect two ribbons from the lens assembly as shown in the second picture.
    • Disconnect the ground wire from the motherboard as shown in the third picture.
  10. Samsung WB150F Motherboard Replacement: passo 10, immagine 1 di 2 Samsung WB150F Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the motherboard from the camera housing.
Conclusione
Wyatt Turner
Membro da: 04/12/22
265 Reputazione
3 Guide realizzate
IUPUI, Team 7-7, Beck Spring 2022 Membro di IUPUI, Team 7-7, Beck Spring 2022
IUPUI-BECK-S22S7G7
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 193
