Salta al contenuto principale
Samsung WB1100F LCD Screen Replacement
Cosa ti serve
  1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: passo 1, immagine 1 di 2 Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: passo 1, immagine 2 di 2
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
  2. Samsung WB1100F LCD Screen Replacement: passo 2, immagine 1 di 2 Samsung WB1100F LCD Screen Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
  3. Samsung WB1100F LCD Screen Replacement, LCD Screen: passo 3, immagine 1 di 2 Samsung WB1100F LCD Screen Replacement, LCD Screen: passo 3, immagine 2 di 2
    • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
  4. Samsung WB1100F LCD Screen Replacement: passo 4, immagine 1 di 3 Samsung WB1100F LCD Screen Replacement: passo 4, immagine 2 di 3 Samsung WB1100F LCD Screen Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Flip the LCD screen over to reveal the display cable.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
Conclusione
Jesse Lindsey
Membro da: 05/13/16
581 Reputazione
5 Guide realizzate
Metro State, Team 1-1, Carpenter SU 2016 Membro di Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 713
