Salta al contenuto principale
Samsung UBD-M8500 Outer Shell Replacement
Cosa ti serve
  1. Samsung UBD-M8500 Outer Shell Replacement, Outer Shell: passo 1, immagine 1 di 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Outer Shell Replacement: passo 2, immagine 1 di 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Outer Shell Replacement: passo 3, immagine 1 di 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Outer Shell Replacement: passo 4, immagine 1 di 1
    • Remove the cover of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 99
