Salta al contenuto principale
Samsung U28E510 Jog Button Replacement
Cosa ti serve
  1. Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, immagine 1 di 3 Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, immagine 2 di 3 Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, immagine 3 di 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: passo 2, immagine 1 di 2 Samsung U28E510 Jog Button Replacement: passo 2, immagine 2 di 2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: passo 3, immagine 1 di 1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Conclusione
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
Altre 3 persone hanno completato questa guida.
Jake Ritter
Membro da: 01/22/18
106 Reputazione
1 Guida realizzata
Cal Poly, Team S11-G1, Banghart Winter 2018 Membro di Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Membri
6 Guide realizzate
5 Commenti
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Replica
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Replica
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Replica
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 86
Tutti i Tempi: 6,455
