Introduzione
All you need for this guide is the will to fix your camera. Enjoy!
Cosa ti serve
Check for debris and dust around the power button to make sure it's clean.
If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
Now carefully pry open the back casing with the ifixit plastic opening tool.
Altre 2 persone hanno completato questa guida.
