Salta al contenuto principale
Samsung TFT Color YP-T7J The Battery Replacement
Cosa ti serve
  1. Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: passo 1, immagine 1 di 2 Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: passo 1, immagine 2 di 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Battery Replacement: passo 2, immagine 1 di 2 Samsung TFT Color YP-T7J The Battery Replacement: passo 2, immagine 2 di 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Battery Replacement: passo 3, immagine 1 di 3 Samsung TFT Color YP-T7J The Battery Replacement: passo 3, immagine 2 di 3 Samsung TFT Color YP-T7J The Battery Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Battery Replacement, The Battery: passo 4, immagine 1 di 2 Samsung TFT Color YP-T7J The Battery Replacement, The Battery: passo 4, immagine 2 di 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Battery Replacement: passo 5, immagine 1 di 2 Samsung TFT Color YP-T7J The Battery Replacement: passo 5, immagine 2 di 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
Conclusione
Dylan Peters
Membro da: 10/18/13
409 Reputazione
4 Guide realizzate
Clemson, Team 14-8, Benson Fall 2013 Membro di Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Membri
7 Guide realizzate
Un commento
Nice instructions. Any idea where I can purchase a new battery that will fit?
grgermain - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,909
