Salta al contenuto principale
Samsung TFT Color YP-T7J Front Cover Button Replacement
Cosa ti serve
  1. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: passo 1, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: passo 1, immagine 2 di 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 2, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 2, immagine 2 di 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 3, immagine 1 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 3, immagine 2 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: passo 4, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: passo 4, immagine 2 di 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 5, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 5, immagine 2 di 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, immagine 1 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, immagine 2 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, immagine 3 di 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: passo 7, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: passo 7, immagine 2 di 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 8, immagine 1 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 8, immagine 2 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 8, immagine 3 di 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 9, immagine 1 di 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 10, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 10, immagine 2 di 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: passo 11, immagine 1 di 2 Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: passo 11, immagine 2 di 2
    • Once the front cover is separated from the device, locate the four screws in the metal plate.
    • Using the small phillips screw driver, remove the four screws.
    • Remove the metal cover.
  12. Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 12, immagine 1 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 12, immagine 2 di 3 Samsung TFT Color YP-T7J Front Cover Button Replacement: passo 12, immagine 3 di 3
    • Remove the rubber button pad.
Conclusione
Jason Farr
Membro da: 10/21/13
353 Reputazione
3 Guide realizzate
Clemson, Team 14-8, Benson Fall 2013 Membro di Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 817
