Salta al contenuto principale
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: passo 3, immagine 1 di 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Conclusione
Austin
Membro da: 07/11/13
201 Reputazione
2 Guide realizzate
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 299
