Salta al contenuto principale
Samsung Series 9 NP900X3C-A02US Touch Pad Replacement
Cosa ti serve
  1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement, Touch Pad: passo 1, immagine 1 di 1
    • Shut down the laptop.
    • Power off the laptop by navigating the window icon on the bottom left and clicking on the power followed by shutdown.
  2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 2, immagine 1 di 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 2, immagine 2 di 2
    • Remove the back cover of the laptop by using a Phillips #00 screwdriver to remove ten 2 mm screws.
    • Pry out the bottom panel on all sides using a prying tool.
  3. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 3, immagine 1 di 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 3, immagine 2 di 3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 3, immagine 3 di 3
    • Unscrew the internal battery and disconnect it from the motherboard.
    • Remove all the cables, tapes by using the tools such as plastic spudgers.
    • Look for the ribbon cable connection and by using the spudger to pull up the clip and unlock the ribbon cable.
  4. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 4, immagine 1 di 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 4, immagine 2 di 2
    • Peel out any tapes holding the touchpad carefully.
  5. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 5, immagine 1 di 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 5, immagine 2 di 2
    • By using the prying tool unstick and detach the module.
  6. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 6, immagine 1 di 2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: passo 6, immagine 2 di 2
    • Remove four 0.1mm screws using a Phillips #00 Screwdriver from the laptop.
    • Open the laptop a little bit to create space to drop the touchpad module by pushing it gently downwards.
    • After taking out the touchpad clean it especially at the edges and the corners by using rubbing alcohol and microfiber cloth.
Conclusione
Ghaniyah Gul
Membro da: 02/07/23
391 Reputazione
2 Guide realizzate
Gateway, Team A-2, Gonzalez Spring 2023 Membro di Gateway, Team A-2, Gonzalez Spring 2023
GCC-GONZALEZ-S23SAG2
5 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 157
