Salta al contenuto principale
Samsung Series 9 NP900X3A Back Panel Replacement
Cosa ti serve
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, immagine 1 di 3 Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, immagine 2 di 3 Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, immagine 3 di 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,141
