Salta al contenuto principale
Introduzione
Proving once again that thin and light can still be repairable when thoughtfully designed, the Series 9 15" scores a near-perfect 9 out of 10.
  1. Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: passo 1, immagine 1 di 3 Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: passo 1, immagine 2 di 3 Samsung Series 9 15" Repairability Assessment, Samsung Series 9 15" Repairability Assessment: passo 1, immagine 3 di 3
    • Reference shots.
  2. Samsung Series 9 15" Repairability Assessment: passo 2, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 2, immagine 2 di 2
    • Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off.
    • It's clipped in along the back edge but not very strongly.
    • Internal view.
    • This is seriously cool. From here we can remove: SSD, RAM, battery, right speaker, display assembly, wireless card, (modular!) headphone jack and thermal assembly.
    • That's pretty much everything you'd ever want to tinker with in a laptop. The only commonly-replaced components we can't reach is the keyboard, trackpad, and motherboard.
  3. Samsung Series 9 15" Repairability Assessment: passo 3, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 3, immagine 2 di 2
    • To keep things uniform, we're starting with the battery.
    • It's held in with seven Phillips screws and comes out in a flash.
  4. Samsung Series 9 15" Repairability Assessment: passo 4, immagine 1 di 3 Samsung Series 9 15" Repairability Assessment: passo 4, immagine 2 di 3 Samsung Series 9 15" Repairability Assessment: passo 4, immagine 3 di 3
    • We then start picking parts off the motherboard and the peripheries.
    • Along the way, we discover room for not one, but two RAM modules.
    • That addition, along with the standard, removable SSD means this laptop is super upgradable.
  5. Samsung Series 9 15" Repairability Assessment: passo 5, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 5, immagine 2 di 2
    • We could remove the motherboard at this point, but pause to take a look at this trackpad.
    • Seemingly held in place with just five screws, but we remove them and it won't budge.
    • Then we peel off this pair of taped-in brackets, pry from the top bracket, and successfully remove the trackpad assembly.
  6. Samsung Series 9 15" Repairability Assessment: passo 6, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 6, immagine 2 di 2
    • Next up is the fan. It's secured with two screws.
    • And the daughterboard. After unscrewing three Phillips screws it will not budge, so we had to break up the adhesive holding it in.
  7. Samsung Series 9 15" Repairability Assessment: passo 7, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 7, immagine 2 di 2
    • Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge.
  8. Samsung Series 9 15" Repairability Assessment: passo 8, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 8, immagine 2 di 2
    • Finally we remove three screws from each of the display hinges and the display assembly is free.
  9. Samsung Series 9 15" Repairability Assessment: passo 9, immagine 1 di 2 Samsung Series 9 15" Repairability Assessment: passo 9, immagine 2 di 2
    • The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • All screws are Phillips screws.
    • RAM, SSD, and battery are all easily replaced.
    • Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
    • A moderate amount of adhesive on the I/O board and trackpad brackets complicates some reassembly procedures.
    • Manufacturer does not provide user-accessible repair documentation.
Linea Traguardo
Altre 10 persone hanno completato questa guida.
Evan Noronha
Membro da: 05/02/2015
214.954 Reputazione
177 Guide realizzate
The Home Depot Membro di The Home Depot
Community
9.699 Membri
1.027 Guide realizzate
2 Commenti
how would one repair water vapor trapper in between the touch panel glass?
cooperbeaman - Replica
Sadly when you pulled back the bezel you missed that it’s not a separate LCD but part of the top cover those screws at the bottom just hold a panel in place at the bottom.
Good guide otherwise.
Gaspard Leon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 127
Tutti i Tempi: 11,843
