Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show how to remove the covers from the underside of the laptop, remove the battery, and replace it with the new battery.
  1. Power off the device. Remove the remaining screws holding the back cover in place: Six 4.0 mm Phillips #00 screws.
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Remove the two rubber pads concealing the final bottom case screws. Remove the two 4 mm Phillips #00 screws found under these pads.
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. There are clips along the edges of the back cover that hold it in place. Be careful not to break these. Remove the entire rest of the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Remove the tape holding the wires in place. Remove the tape holding the wires in place.
    • Remove the tape holding the wires in place.
  5. Remove the following Phillips 00 screws securing the battery:
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Pull the battery connector towards the battery to disconnect it.
    • Pull the battery connector towards the battery to disconnect it.
  7. Remove the battery from the laptop.
    • Remove the battery from the laptop.
Conclusione
Altre 12 persone hanno completato questa guida.
Timothy
Membro da: 30/01/2015
1.497 Reputazione
5 Guide realizzate
USF Tampa, Team 16-3, Watkins Winter 2015 Membro di USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Membri
5 Guide realizzate
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Replica
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 157
Tutti i Tempi: 23,548
