Introduzione
Follow this guide if you want to replace the back cover of your Samsung Series 5 3G Chromebook. Removing the back cover exposes all the internal components of the laptop. This will void your warranty, so use caution and be sure not to damage any of the components inside.
Parti
Nessuna parte specificata.
Make sure your Chromebook is powered off before you begin.
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
Remove all the seven screws in the bottom panel.
Altre 3 persone hanno completato questa guida.
