Salta al contenuto principale
Samsung SPH-M360 Logic Board Replacement
Cosa ti serve
  1. Samsung SPH-M360 Logic Board Replacement, Battery: passo 1, immagine 1 di 3 Samsung SPH-M360 Logic Board Replacement, Battery: passo 1, immagine 2 di 3 Samsung SPH-M360 Logic Board Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Logic Board Replacement: passo 2, immagine 1 di 3 Samsung SPH-M360 Logic Board Replacement: passo 2, immagine 2 di 3 Samsung SPH-M360 Logic Board Replacement: passo 2, immagine 3 di 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Logic Board Replacement, Casing: passo 3, immagine 1 di 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Logic Board Replacement: passo 4, immagine 1 di 2 Samsung SPH-M360 Logic Board Replacement: passo 4, immagine 2 di 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Logic Board Replacement: passo 5, immagine 1 di 2 Samsung SPH-M360 Logic Board Replacement: passo 5, immagine 2 di 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Logic Board Replacement, Logic Board: passo 6, immagine 1 di 1
    • Use the plastic opening tool to gently detach the golden strip from the logic board.
    • The strip should detach easily with little force required.
  7. Samsung SPH-M360 Logic Board Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
  8. Samsung SPH-M360 Logic Board Replacement: passo 8, immagine 1 di 2 Samsung SPH-M360 Logic Board Replacement: passo 8, immagine 2 di 2
    • Flip the logic board over and locate the three screws along the edges.
    • Carefully unscrew the three screws to remove the panel covering the logic board.
    • Be careful with the screws after unscrewing them because they are small and easy to lose.
  9. Samsung SPH-M360 Logic Board Replacement: passo 9, immagine 1 di 2 Samsung SPH-M360 Logic Board Replacement: passo 9, immagine 2 di 2
    • Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board.
    • This will not require much force, so be gentle.
Conclusione
Ashraf Nasser
Membro da: 10/22/15
126 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 203
