Salta al contenuto principale
Samsung SPH-M360 Keyboard Replacement
Cosa ti serve
  1. Samsung SPH-M360 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Samsung SPH-M360 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Samsung SPH-M360 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Keyboard Replacement: passo 2, immagine 1 di 3 Samsung SPH-M360 Keyboard Replacement: passo 2, immagine 2 di 3 Samsung SPH-M360 Keyboard Replacement: passo 2, immagine 3 di 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Keyboard Replacement, Casing: passo 3, immagine 1 di 1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Keyboard Replacement: passo 4, immagine 1 di 2 Samsung SPH-M360 Keyboard Replacement: passo 4, immagine 2 di 2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Keyboard Replacement: passo 5, immagine 1 di 2 Samsung SPH-M360 Keyboard Replacement: passo 5, immagine 2 di 2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 1
    • Flip open the phone so that the text on the keyboard is visible.
    • Push from the text side until the keyboard comes completely out of the phone casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 78
