Salta al contenuto principale
Samsung SPH-A500 Speaker Replacement
Cosa ti serve
  1. Samsung SPH-A500 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: passo 2, immagine 1 di 1
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: passo 3, immagine 1 di 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: passo 4, immagine 1 di 1
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: passo 7, immagine 1 di 1
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
Conclusione
Cal Poly, Team 18-100, Johann Spring 2010 Membro di Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,336
