Salta al contenuto principale
Introduzione
This is a step by step guide on how to replace the Samsung SPH-A500 logic board.
Parti
Nessuna parte specificata.
  1. Turn phone over
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Remove all four screws using a small Philips screwdriver.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  5. Remove back cover by carefully prying it open.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  6. Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  7. Look for the clip at the top right corner of the logic board.
    • Look for the clip at the top right corner of the logic board.
  8. Remove the clip from the logic board.
    • Remove the clip from the logic board.
  9. Remove the logic board.
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Conclusione
Nick Dominikovic
Membro da: 13/04/2010
139 Reputazione
4 Guide realizzate
Cal Poly, Team 18-100, Johann Spring 2010 Membro di Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,888
