Salta al contenuto principale
Samsung SPH-A500 Keypad Replacement
Cosa ti serve
  1. Samsung SPH-A500 Keypad Replacement, Keypad: passo 1, immagine 1 di 1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Keypad Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Keypad Replacement: passo 3, immagine 1 di 1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Keypad Replacement: passo 4, immagine 1 di 1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Keypad Replacement: passo 5, immagine 1 di 1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
  6. Samsung SPH-A500 Keypad Replacement: passo 6, immagine 1 di 1
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
  7. Samsung SPH-A500 Keypad Replacement: passo 7, immagine 1 di 1
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
  8. Samsung SPH-A500 Keypad Replacement: passo 8, immagine 1 di 1
    • Replace the keypad.
Conclusione
Cal Poly, Team 18-100, Johann Spring 2010 Membro di Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,045
