Salta al contenuto principale
Samsung SPH-A500 Front LCD Display Replacement
Cosa ti serve
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: passo 1, immagine 1 di 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: passo 3, immagine 1 di 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: passo 4, immagine 1 di 1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: passo 5, immagine 1 di 1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: passo 6, immagine 1 di 1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: passo 7, immagine 1 di 1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Conclusione
Derek Panger
Membro da: 04/16/10
21 Reputazione
1 Guida realizzata
Cal Poly, Team 18-100, Johann Spring 2010 Membro di Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,441
