Salta al contenuto principale
Samsung SGH-X105 Earpiece Speaker Replacement
Cosa ti serve
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, immagine 1 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, immagine 2 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 2, immagine 3 di 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: passo 3, immagine 1 di 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, immagine 1 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, immagine 2 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 4, immagine 3 di 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: passo 5, immagine 1 di 2 Samsung SGH-X105 Earpiece Speaker Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: passo 6, immagine 1 di 1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, immagine 1 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, immagine 2 di 3 Samsung SGH-X105 Earpiece Speaker Replacement: passo 7, immagine 3 di 3
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
Conclusione
Chris Lao
Membro da: 04/15/10
16 Reputazione
1 Guida realizzata
Cal Poly, Team 28-29, Regan Spring 2010 Membro di Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Membri
12 Guide realizzate
Un commento
Where can I get a replacement speaker?
NickyPhils - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,960
