Salta al contenuto principale
Samsung SGH-T639 Motherboard Replacement
Cosa ti serve
  1. Samsung SGH-T639 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Motherboard Replacement, SIM Card: passo 3, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement, SIM Card: passo 3, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement, SIM Card: passo 3, immagine 3 di 3
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  5. Samsung SGH-T639 Motherboard Replacement: passo 5, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement: passo 5, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement: passo 5, immagine 3 di 3
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  6. Samsung SGH-T639 Motherboard Replacement: passo 6, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement: passo 6, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement: passo 6, immagine 3 di 3
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  7. Samsung SGH-T639 Motherboard Replacement: passo 7, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement: passo 7, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement: passo 7, immagine 3 di 3
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  8. Samsung SGH-T639 Motherboard Replacement: passo 8, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement: passo 8, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement: passo 8, immagine 3 di 3
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  9. Samsung SGH-T639 Motherboard Replacement: passo 9, immagine 1 di 3 Samsung SGH-T639 Motherboard Replacement: passo 9, immagine 2 di 3 Samsung SGH-T639 Motherboard Replacement: passo 9, immagine 3 di 3
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  10. Samsung SGH-T639 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the motherboard from the cell phone.
Conclusione
Yi Ren
Membro da: 03/26/14
801 Reputazione
8 Guide realizzate
Clemson, Team 1-4, Benson Spring 2014 Membro di Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 286
