Salta al contenuto principale
Samsung SGH-E317 Motherboard Replacement
Cosa ti serve
  1. Samsung SGH-E317 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: passo 2, immagine 1 di 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: passo 5, immagine 1 di 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: passo 6, immagine 1 di 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: passo 7, immagine 1 di 2 Samsung SGH-E317 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: passo 8, immagine 1 di 2 Samsung SGH-E317 Motherboard Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: passo 9, immagine 1 di 2 Samsung SGH-E317 Motherboard Replacement: passo 9, immagine 2 di 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Conclusione
Chris Dimler
Membro da: 01/22/11
124 Reputazione
1 Guida realizzata
Cal Poly, Team 11-23, Maness Winter 2011 Membro di Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,393
