Salta al contenuto principale
Samsung SGH-A737 Camera Replacement
Cosa ti serve
  1. Samsung SGH-A737 Camera  Replacement, Equipment and Tools: passo 1, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Equipment and Tools: passo 1, immagine 2 di 2
    • Gather all the materials required prior to the teardown.
    • A Phillips PH000 screw head and screwdriver are the only required tools for this guide.
    • Make sure to use the correct screwdriver head in order to avoid damaging screw heads.
    • Avoid over tightening the screws to avoid damaging them.
  2. Samsung SGH-A737 Camera  Replacement, Battery: passo 2, immagine 1 di 3 Samsung SGH-A737 Camera  Replacement, Battery: passo 2, immagine 2 di 3 Samsung SGH-A737 Camera  Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the battery from the back of the device.
    • To do this, slide the battery cover off the rear side of the phone.
    • Once the rear cover is removed, the battery should easily pop out of the phone.
  3. Samsung SGH-A737 Camera  Replacement, Back Cover: passo 3, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Back Cover: passo 3, immagine 2 di 2
    • Using the screwdriver, unscrew the six visible screw drivers on the back of the phone.
    • Be sure to use the proper size of screwdriver. If you don't you may risk damaging the outer container of the device.
  4. Samsung SGH-A737 Camera  Replacement, Side Buttons: passo 4, immagine 1 di 1
    • Next, remove the side buttons by gently prying them off.
    • When the phone is reassembled, these buttons will be placed back in their appropriate holder.
  5. Samsung SGH-A737 Camera  Replacement, Circuit Board: passo 5, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Circuit Board: passo 5, immagine 2 di 2
    • With care, lift up the connector located at the bottom left of the phone, as demonstrated in the accompanying image.
  6. Samsung SGH-A737 Camera  Replacement, Circuit Board Continued: passo 6, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Circuit Board Continued: passo 6, immagine 2 di 2
    • Flip the circuit board up to unveil an orange connector near bottom of it.
    • Gently unplug the connector by prying on the corner with a finger.
  7. Samsung SGH-A737 Camera  Replacement, Circuit Board Holder: passo 7, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Circuit Board Holder: passo 7, immagine 2 di 2
    • Lift up the tan circuit board holder to separate it from the device.
  8. Samsung SGH-A737 Camera  Replacement, Sliding Panel: passo 8, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Sliding Panel: passo 8, immagine 2 di 2
    • Peel off the black strip below the product sticker, unveiling two screws and unscrew them.
    • There are two more screws slightly below that need to be unscrewed as well.
    • Be sure to use the proper size screwdriver. Using the wrong size can cause damage to the case!
  9. Samsung SGH-A737 Camera  Replacement, Sliding Panel Continued: passo 9, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Sliding Panel Continued: passo 9, immagine 2 di 2
    • Make sure the phone is closed. If not slide it closed now.
    • Next, carefully detach the blue plastic panel from the phone. It should already be slightly loose.
    • When sliding the connector through the rectangular gap, be sure to do so gently in order to avoid any damage.
  10. Samsung SGH-A737 Camera  Replacement, Camera Panel: passo 10, immagine 1 di 2 Samsung SGH-A737 Camera  Replacement, Camera Panel: passo 10, immagine 2 di 2
    • Begin by removing the six visible screws located on the outer edge of the device.
    • Once the screws are removed, gently separate the panel to unveil the circuits and camera.
  11. Samsung SGH-A737 Camera  Replacement, Camera Replacement: passo 11, immagine 1 di 3 Samsung SGH-A737 Camera  Replacement, Camera Replacement: passo 11, immagine 2 di 3 Samsung SGH-A737 Camera  Replacement, Camera Replacement: passo 11, immagine 3 di 3
    • Be sure to perform these steps using as little force as possible. The circuit boards can be delicate!
    • To disconnect the camera, gently lift the tan flap away from the camera where the orange connector is attached. This should loosen the wire.
    • Next, pry up on the camera to dislodge it. This may require some force.
Conclusione
Tommy
Membro da: 02/19/16
101 Reputazione
2 Guide realizzate
Ohio State, Team 1-3, Garvin Spring 2016 Membro di Ohio State, Team 1-3, Garvin Spring 2016
OSU-GARVIN-S16S1G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 273
