Salta al contenuto principale
Samsung SGH-A237 Logic Board Replacement
Cosa ti serve
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: passo 1, immagine 1 di 2 Samsung SGH-A237 Logic Board Replacement, Logic Board: passo 1, immagine 2 di 2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: passo 2, immagine 1 di 2 Samsung SGH-A237 Logic Board Replacement: passo 2, immagine 2 di 2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: passo 3, immagine 1 di 2 Samsung SGH-A237 Logic Board Replacement: passo 3, immagine 2 di 2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: passo 4, immagine 1 di 3 Samsung SGH-A237 Logic Board Replacement: passo 4, immagine 2 di 3 Samsung SGH-A237 Logic Board Replacement: passo 4, immagine 3 di 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: passo 5, immagine 1 di 1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: passo 6, immagine 1 di 2 Samsung SGH-A237 Logic Board Replacement: passo 6, immagine 2 di 2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Conclusione
Cal Poly, Team 29-81, Johann Spring 2010 Membro di Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,805
