Salta al contenuto principale
Samsung SGH-A237 Keypad Replacement
Cosa ti serve
  1. Samsung SGH-A237 Keypad Replacement, Keypad: passo 1, immagine 1 di 2 Samsung SGH-A237 Keypad Replacement, Keypad: passo 1, immagine 2 di 2
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: passo 2, immagine 1 di 2 Samsung SGH-A237 Keypad Replacement: passo 2, immagine 2 di 2
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: passo 3, immagine 1 di 2 Samsung SGH-A237 Keypad Replacement: passo 3, immagine 2 di 2
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: passo 4, immagine 1 di 3 Samsung SGH-A237 Keypad Replacement: passo 4, immagine 2 di 3 Samsung SGH-A237 Keypad Replacement: passo 4, immagine 3 di 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: passo 5, immagine 1 di 1
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: passo 6, immagine 1 di 2 Samsung SGH-A237 Keypad Replacement: passo 6, immagine 2 di 2
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: passo 7, immagine 1 di 1
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Conclusione
Shawn
Membro da: 04/14/10
1 Reputazione
2 Guide realizzate
Cal Poly, Team 29-81, Johann Spring 2010 Membro di Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Membri
8 Guide realizzate
Un commento
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,316
