Salta al contenuto principale
Samsung SGH-A137 Keypad Replacement
Cosa ti serve
  1. Samsung SGH-A137 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Keypad Replacement: passo 2, immagine 1 di 1
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, immagine 1 di 3 Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, immagine 2 di 3 Samsung SGH-A137 Keypad Replacement, Motherboard: passo 3, immagine 3 di 3
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Keypad Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Keypad Replacement: passo 5, immagine 1 di 2 Samsung SGH-A137 Keypad Replacement: passo 5, immagine 2 di 2
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Keypad Replacement: passo 6, immagine 1 di 1
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
  7. Samsung SGH-A137 Keypad Replacement, Keypad: passo 7, immagine 1 di 1
    • Gently push the keypad out toward the back.
  8. Samsung SGH-A137 Keypad Replacement: passo 8, immagine 1 di 1
    • Replace the defective keypad and reassemble the phone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 295
