Salta al contenuto principale
Samsung SGH-A117 Motherboard Replacement
Cosa ti serve
  1. Samsung SGH-A117 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. Samsung SGH-A117 Motherboard Replacement: passo 2, immagine 1 di 1
    • Lift the bottom of the battery and then move it up and away.
  3. Samsung SGH-A117 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. Samsung SGH-A117 Motherboard Replacement: passo 4, immagine 1 di 1
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. Samsung SGH-A117 Motherboard Replacement: passo 5, immagine 1 di 1
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A117 Motherboard Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 235
