Strumenti necessari in questo Smontaggio
Introduzione
Samsung SGH-A117 is a basic flip phone. This guide will describe the steps required for disassembling and reassembling the phone.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung SGH-A117, usa il nostro manuale di assistenza.
This is the Samsung SGH-A117.
  • This is the Samsung SGH-A117.
Aggiungi Commento
This is the back view following the removal of the back cover and battery.
  • This is the back view following the removal of the back cover and battery.
Aggiungi Commento
  • Use a screwdriver to remove screws around the frame.
  • Use a PH00 size screw to operate this step.
  • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
Aggiungi Commento
  • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
  • The end of the phone closest to the hinge will require additional force to lift.
  • Be careful not to bend the cover during the removal process.
Aggiungi Commento
  • Use a spudger to gently lift the circuit connector from the logic board.
  • Be careful not to remove the circuit connector from the phone.
Aggiungi Commento
  • Use a spudger to lift the logic board and separate it from the main body of the phone.
  • It is recommended to lift from the bottom part of the logic board as shown in the picture.
  • Be careful not to lose the volume button, which is loosely attached to the logic board.
Aggiungi Commento
  • Gently push the keyboard from the case as shown in the picture.
Aggiungi Commento
  • 1 Case
  • 1 Keyboard
  • 1 Logic Board
  • 1 Volume Control
  • 1 Back Cover
  • 5 Screws
Aggiungi Commento
Justin
Membro da: 06/10/2014
138 Reputazione
2 Guide realizzate
Aristotle Membro di Aristotle
Community
5 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 415
