Introduzione
Use this guide to replace your Samsung SGH A707 phone's front pane.
Cosa ti serve
Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
Hold the phone and gently separate the circuit board that holds the dome switches and the front face of the phone, revealing the rubber keyboard.
Use the Phillips #0 screw driver to remove the two screws.
Place the screws in a safe place.
Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
