Salta al contenuto principale
Samsung SGH A707 Display Replacement
Cosa ti serve
  1. Samsung SGH A707 Display Replacement, Battery: passo 1, immagine 1 di 1
    • Press on the markings on the cover and pull it down to reveal the battery.
  2. Samsung SGH A707 Display Replacement: passo 2, immagine 1 di 1
    • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  3. Samsung SGH A707 Display Replacement: passo 3, immagine 1 di 1
    • Here is the phone without the battery.
  4. Samsung SGH A707 Display Replacement, Motherboard: passo 4, immagine 1 di 2 Samsung SGH A707 Display Replacement, Motherboard: passo 4, immagine 2 di 2
    • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  5. Samsung SGH A707 Display Replacement: passo 5, immagine 1 di 1
    • Use the prying tool the pry off the phone's plastic frame.
  6. Samsung SGH A707 Display Replacement: passo 6, immagine 1 di 3 Samsung SGH A707 Display Replacement: passo 6, immagine 2 di 3 Samsung SGH A707 Display Replacement: passo 6, immagine 3 di 3
    • Use the prying tool to disconnect the rectangular connector.
  7. Samsung SGH A707 Display Replacement: passo 7, immagine 1 di 1
    • Use the prying tool to disconnect the small connector.
  8. Samsung SGH A707 Display Replacement: passo 8, immagine 1 di 1
    • Gently pull off the circuit board.
  9. Samsung SGH A707 Display Replacement: passo 9, immagine 1 di 1
    • Here is the phone without the logic board.
  10. Samsung SGH A707 Display Replacement, Front Pane: passo 10, immagine 1 di 2 Samsung SGH A707 Display Replacement, Front Pane: passo 10, immagine 2 di 2
    • Use the Phillips #0 screw driver to remove the two screws.
    • Place the screws in a safe place.
    • Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
  11. Samsung SGH A707 Display Replacement: passo 11, immagine 1 di 1
    • Now we have access to the camera.
    • We also have access to the speakers.
    • Disconnect the flat cable to separate the two pieces.
  12. Samsung SGH A707 Display Replacement: passo 12, immagine 1 di 1
    • Samsung SGH A707
  13. Samsung SGH A707 Display Replacement, Display: passo 13, immagine 1 di 1
    • Separate the two flaps to make handling easier.
    • Use a screw driver to press a latch in along the axis of the hinge and simultaneously pull the pieces apart.
    • Gently pull the flat cable through the hinge.
  14. Samsung SGH A707 Display Replacement: passo 14, immagine 1 di 1
    • Use the prying tool to separate the screen from the rest of the phone.
    • Be careful not to lose the little cube of foam and wire that is under the circuit board. It is important in connecting two different circuits and must be placed back when the phone is reassembled.
  15. Samsung SGH A707 Display Replacement: passo 15, immagine 1 di 2 Samsung SGH A707 Display Replacement: passo 15, immagine 2 di 2
    • Samsung SGH A707
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,411
