Salta al contenuto principale
Samsung SCV-VLUUST50 Cover Replacement
Cosa ti serve
  1. Samsung SCV-VLUUST50 Cover Replacement, Cover: passo 1, immagine 1 di 3 Samsung SCV-VLUUST50 Cover Replacement, Cover: passo 1, immagine 2 di 3 Samsung SCV-VLUUST50 Cover Replacement, Cover: passo 1, immagine 3 di 3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Cover Replacement: passo 2, immagine 1 di 3 Samsung SCV-VLUUST50 Cover Replacement: passo 2, immagine 2 di 3 Samsung SCV-VLUUST50 Cover Replacement: passo 2, immagine 3 di 3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Cover Replacement: passo 3, immagine 1 di 1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Cover Replacement: passo 4, immagine 1 di 2 Samsung SCV-VLUUST50 Cover Replacement: passo 4, immagine 2 di 2
    • Remove the front and back covers by pulling them straight apart.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 179
