Introduzione
A step by step guide to removing and replacing the Samsung SCH U340's internal antennae.
Cosa ti serve
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
Quasi finito!
Conclusione
