Parti
Nessuna parte richiesta.
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  3. Lift battery away from phone case.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
  4. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  5. When unscrewed, pull the antenna straight up and out.
    • When unscrewed, pull the antenna straight up and out.
  6. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  7. Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
  8. Remove the four screws using a T6 Torx screwdriver.
    • Remove the four screws using a T6 Torx screwdriver.
  9. Work from the bottom of the phone, separating the two halves of the case. Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  10. Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
  11. Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end. The Back Cover is now removed. Congratulations. The Back Cover is now removed. Congratulations.
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
  12. Remove the connector for the earpiece speaker, located on the upper end of the logic board.
    • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
  13. Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
    • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
  14. Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered. The logic board is now removed from the phone. Congratulations.
    • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
    • The logic board is now removed from the phone. Congratulations.
  15. Turn the front cover over and shake the keys out of it. They should come free in a single piece. Note: The keypad may accidentally come free while removing rear cover or logic board. It is best to remove the logic board to reinstall the key mat.
    • Turn the front cover over and shake the keys out of it. They should come free in a single piece.
    • Note: The keypad may accidentally come free while removing rear cover or logic board. It is best to remove the logic board to reinstall the key mat.
    • The key pad is now removed from the phone. Congratulations.
Conclusione
Clemson, Team 2-6, Benson Spring 2012 Membro di Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Membri
10 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 737
