Salta al contenuto principale
Samsung S760 Front and Back Case Replacement Guide
Cosa ti serve
  1. Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, immagine 1 di 3 Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, immagine 2 di 3 Samsung S760 Front and Back Case Replacement Guide, Battery: passo 1, immagine 3 di 3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Front and Back Case Replacement Guide: passo 2, immagine 1 di 2 Samsung S760 Front and Back Case Replacement Guide: passo 2, immagine 2 di 2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, immagine 1 di 3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, immagine 2 di 3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: passo 3, immagine 3 di 3
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Front and Back Case Replacement Guide: passo 4, immagine 1 di 2 Samsung S760 Front and Back Case Replacement Guide: passo 4, immagine 2 di 2
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Front and Back Case Replacement Guide: passo 5, immagine 1 di 1
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
Conclusione
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 677
