Introduzione
This guide will take you through the steps of removing parts of your device to reach and replace the lens
Cosa ti serve
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera.
Move the screen down, out of the way to remove the two 3mm screws beneath it.
Altre 4 persone hanno completato questa guida.
2 Commenti
Brilliantly explained. Makes it look so easy… even a fool such as I could follow the instructions.
the guide is actually beautiful im just upset that mine got corroded from battery leakage and rusted the capacitors next to the charging port and caused it to fall off :c
