Salta al contenuto principale
Samsung Rogue Keyboard Replacement
Cosa ti serve
  1. Samsung Rogue Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Samsung Rogue Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Keyboard Replacement: passo 2, immagine 1 di 2 Samsung Rogue Keyboard Replacement: passo 2, immagine 2 di 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Keyboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Keyboard Replacement: passo 4, immagine 1 di 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Keyboard Replacement: passo 5, immagine 1 di 3 Samsung Rogue Keyboard Replacement: passo 5, immagine 2 di 3 Samsung Rogue Keyboard Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Keyboard Replacement: passo 7, immagine 1 di 2 Samsung Rogue Keyboard Replacement: passo 7, immagine 2 di 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Keyboard Replacement: passo 8, immagine 1 di 2 Samsung Rogue Keyboard Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Keyboard Replacement, Keyboard: passo 9, immagine 1 di 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Keyboard Replacement: passo 10, immagine 1 di 1
    • Carefully remove keyboard holder from the slider mechanisms underneath.
  11. Samsung Rogue Keyboard Replacement: passo 11, immagine 1 di 2 Samsung Rogue Keyboard Replacement: passo 11, immagine 2 di 2
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
Conclusione
Cal Poly, Team 7-32, Maness Spring 2012 Membro di Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 308
