Introduzione
This guide will walk you through the process of removing the bottom of the speaker, the outer shell, the subwoofer and accessing the tweeter speaker for removal.
Cosa ti serve
Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
Remove the four 10mm long screws with the Phillips #1 screwdriver.
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
Remove the six 8mm screws using the Phillips #1 screwdriver.
Remove the six 12mm screws using the Phillips #1 screwdriver.
