Salta al contenuto principale
Samsung Radiant 360 R1 Micro USB / Power Port Panel Replacement
Cosa ti serve
  1. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement, Micro USB / Power Port Panel: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: passo 2, immagine 1 di 1
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: passo 3, immagine 1 di 1
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: passo 4, immagine 1 di 1
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: passo 5, immagine 1 di 1
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
Conclusione
Andrew Dutton
Membro da: 02/01/17
122 Reputazione
1 Guida realizzata
UW Tacoma, Team 2-5, Rose Winter 2017 Membro di UW Tacoma, Team 2-5, Rose Winter 2017
UWT-ROSE-W17S2G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 928
