Salta al contenuto principale
Samsung Propel Motherboard Replacement
Cosa ti serve
  1. Samsung Propel Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back panel of the phone.
  2. Samsung Propel Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the old battery and replace with the new one.
  3. Samsung Propel Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Use a flat-head screwdriver to remove the back lid.
  4. Samsung Propel Motherboard Replacement: passo 4, immagine 1 di 1
    • Locate the six screws and remove them with a Phillips #00 Screwdriver.
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge the snap-ons that are beneath the crevice.
    • Remove the back frame of the device.
  5. Samsung Propel Motherboard Replacement: passo 6, immagine 1 di 1
    • Locate and remove the six screws with a Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  6. Samsung Propel Motherboard Replacement: passo 7, immagine 1 di 1
    • Locate and remove the four screws with a Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
    • Be careful not to rip the band.
  7. Samsung Propel Motherboard Replacement: passo 9, immagine 1 di 1
    • Use your hands to remove both the phone buses from the linkages and remove the motherboard.
Conclusione
Minh
Membro da: 04/28/11
201 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,769
