Salta al contenuto principale
Samsung Portable Dualband Tri-Mode Internal Speaker Replacement
Cosa ti serve
  1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: passo 1, immagine 1 di 2 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: passo 2, immagine 1 di 2 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: passo 2, immagine 2 di 2
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: passo 3, immagine 1 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: passo 3, immagine 2 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: passo 3, immagine 3 di 3
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: passo 4, immagine 1 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: passo 4, immagine 2 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: passo 4, immagine 3 di 3
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: passo 5, immagine 1 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: passo 5, immagine 2 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: passo 5, immagine 3 di 3
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: passo 6, immagine 1 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: passo 6, immagine 2 di 3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: passo 6, immagine 3 di 3
    • At the front plate of the phone, locate the internal speaker unit at the top of the front plate.
    • Pry the internal speaker away from the front casing of the phone using a flathead screwdriver.
    • Remove the internal speaker from the front casing.
Conclusione
Barbara
Membro da: 03/26/14
413 Reputazione
4 Guide realizzate
Clemson, Team 6-2, Benson Spring 2014 Membro di Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 235
