Introduzione
Replace the right wheel of your POWERbot. This can be done to resolve a persistent error code (C 03) and/or to simply eliminate movement issues.
Cosa ti serve
Turn off the emergency switch located at the bottom right of the POWERbot.
Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
Remove the three 5mm Phillips #1 screws in the holes around the vacuum motor.
Altre 19 persone hanno completato questa guida.
18 Commenti
Great instructions, thank you. Would you happen to know where I can aquire this part or the gear wheels as that's what I think is the problem. Thanks Stephen Rawlings
GREAT INSTRUCTIONS!!! I would have to say there is a design flaw where the wheel spring attaches. I have two of these vacuums and they both have had the same problem now 4 times the small plastic peice that holds the spring snaps off and you can not reattach the spring. I would assume that there is no quick fix and samsung would sell you the whole drive wheel. Is there a place where you can purchase parts ???
Did you find the answer to this question? Mine has had the same thing happen.
did you manage to fix ?
am i wanting the right wheel motor, are you willing to sell?
nique88 -
Very helpful, thank you!! My son has a 3d printer so may be able to create the part you are still looking for that part, @lightningrods
